[NEBULA] MAC-based Authentication with Nebula Cloud Authentication
I could not find a guide on how to setup MAC-based Authentication for our Wireless Access Points.
It looks like I should be able to set this up so devices should automatically connect to the Wi-Fi if I have added the MAC address to the cloud authentication in the organization?
Please can you let me know if you have a guide for setting this up?
Many thanks,
Jules
Many thanks,
Jules
Hi @Jules
Your SSID's authentication must also have MAC-based authentication enabled.
AP > Configure > Authentication
MAC-based Authentication with Nebula cloud authentication allows clients whose MAC address is in the cloud authentication to connect to the SSID.
We will post a proper guide for MAC-based authentication on the forums to better support our users.
Best regards,
Barney Gregorio5
Hi @Jules
Best regards,
Barney Gregorio5 -
Thanks Barney.
After trying a few different setups, I can see how it works now. Only the authorised MAC addresses are allowed access. Even if the device has the WPA2 Pre-shared key, it can only connect if the MAC address is on the list.
Guide for MAC-based Authentication for Wireless Network has been posted in the FAQ section.
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
