USG FLEX 100H crashing/freezing problem
Ugur
Ugur Posts: 1 image  Freshman Member
I have been using USG FLEX 100 H. It has been crashing/freezing every 3-4 days. I cannot reach/ping the firewall. DHCP stops running and wont assign any ip s. Only restarts solves the problem. I have the latest firmware. Can you please help me to solve this huge problem. Thanks
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    edited August 2024 Answer ✓
    Hi @Ugur,
    We found that some of the firewall freeze issue is related to the DDoS attacks. Please help to reference this FAQ to check if the solution works.
    How to mitigate DDos Attacks? — Zyxel Community
    If not, please help to collect the diagnostic information and send it to me for checking. I will DM you for the request.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Ugur,
    Zyxel Melen
