VMG3625-T50B
amsteen
I have a new router VMG3625-T50B with a problem that
router page WAN IP different from the public IP
so I borrowed a router from a friend and replace my router with it, adding settings and work perfect , the router page WAN IP now is the same as public IP.
I am sure now that the problem is from VMG3625-T50B
so is there any setting to fix this issue ??
I thought maybe you could try comparing the WAN settings on the two devices.
Hi @amsteen
I have a couple of thoughts of questions and thoughts:
- Is your Zyxel router directly connected to your ISP, or is it via a separate modem?
- If you have a separate modem, then that might give your Zyxel router a private IP address with the modem having the public IP address.
- What firmware version is in your Zyxel router?
Kind regards,
Tony
0 - Is your Zyxel router directly connected to your ISP, or is it via a separate modem?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
