port forwardinfg not work?
IkkI_Magna
IkkI_Magna Posts: 17 image  Freshman Member
edited August 2024 in Security
i have set NAT and policy access in Zyxel USG110
SYNNAS is snology which has started DDNS function,that mean port of NAS has been opened.
however, result of https://www.yougetsignal.com/tools/open-ports/
is Port 5001 is closed on your IP…
I have ref this youtube already, but seem failed:
Any one get idea?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    Hi @IkkI_Magna,
    Is your WAN using PPPoE? If yes, you might need to select "WAN1_PPP" instead of WAN1.
    Zyxel Melen
  • Zyxel_Melen
    Hi @IkkI_Magna,
    Zyxel Melen
