NWA50AX - some device no longer connect since the firmware update
Hi @darxmurf
Thank you for your information.
We are currently investigating the issue and will keep you updated.
Nami
Hello @darxmurf
I wanted to provide an update on this case.
Based on your diagnostic file and description, the 2.4GHz SSID goes down after rebooting the device 2-3 times. The current workaround is adjusting some parameters in the web GUI, which makes it visible again.
This issue will be addressed in the next official firmware release. If anyone encounters this issue with firmware 7.00, please collect the diagnostic info when the issue reoccurs and send us via private message.
Thanks for your understanding.
Nami
Hi @Zyxel_Nami
Is this fix in v7 Patch 2 that has recently been announced and released, or will it be in a future v7 Patch 3?
I can't see anything specific in the v7 Patch 2 release notes that mentions this issue being resolved.
Lewis.
Hi Lewis @Lewpy
It will be addressed in a future official firmware update, not in version 7.00 patch 2, which was recently released a few days ago.
Nami
Hi @Zyxel_Nami .
I'm encountering the same issue using a NWA50AX-PRO.
Until today my AccessPoint was on firmware V7.0 Patch 1. Today installed 7.0 Patch 2.
I will send you the diagnostic file via PM.
Hello @e_mano_e
Thank you for providing the diagnostic information.
To assist you better, could you please provide more details about the issue you're experiencing?
We are currently addressing similar issues on the following models: NWA50AX, NWA90AX, and NWA55AXE. Your additional details will help us understand if your situation aligns with these ongoing investigations.
Nami
My NWA50AX-PRO is powered by PoE using the Zyxel GS1900-24EP switch.
The specific switch port for the NWA50AX-PRO is configured using a schedule plan.
The switch shuts-off the NWA50AX-PRO at 23:59 and gives PoE power back in the morning at 6:00.
This worked without problems but since firmware 7.0 Patch 1 the SSID was missing, so my mobile phone cannot connect to the switch.
Hello @e_mano_e
We have reviewed the diagnostic information and found that the 2.4GHz interface of the AP functions normally with one client connected. Additionally, we tried to reproduce your case with the NWA50AX PRO powered by a PoE Switch, and the 2.4GHz SSID is available.
To further investigate, please help us by collecting the diagnostic information when the issue reoccurs, and provide us with the timestamp and the client's MAC address.
Thank you
Nami
Same issue, I have 2 NWAX50 access points, both upgraded this morning to the latest release.
Firstfloor access point is working normally on both 2.4Ghz and 5Ghz
Groundfloor access point was no longer visible on channel 1 for 2.4Ghz. 5Ghz was working ok.
Additionally, the status information for the groundfloor AP is not being propagated into nebula.
I've tried rebooting and power cycling to no affect.
After changing the 2.4GHz channel config the groundfloor is now visible and I can connect to it using a client, but nebula is still not showing any clients connected.
If I check Site-wide → Clients, all clients are connected to the 1st floor access point.
The known clients connected to the ground floor are listed as offline.
Checking I can see a client connected in the event logs for the ground floor access point.
Summary:
Changing the channel seems to bring the 2.4 Ghz online as a temporary fix, but it seems to have stopped reporting info into Nebula.
Hi @tom_b
To investigate further, please help enable Zyxel Support Access and provide your Org/Site name.
Thank you
Nami
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 485 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
