Lte5398-M904 latest firmware (actual is v1.00(ACBQ.0)b6 ITALY
Hi vgkit,
Please contact Wind Tre for this case because it's up to them if any new firmware can be released.
Regards,
Bob0 -
Hi @vgkit
Christophe @CTOLZANE pointed out that there is the V1.00(ABQV.2)C0 firmware available for download from https://www.studerus.ch/fr/support/downloadcenter even if it is not on the Zyxel website.
You might still want to contact Wind TRE to confirm that you are ok to use it as Bob @Bob_C suggests.
Kind regards,
Tony1 -
Hi, I updated the router with the FW. VER..V1.00 (ABQV.4) C0, and the "VOLTE" telephony function with Windtre no longer works.How can I do to solve the problem?Can I downgrade the device fw or put another version of FW?
Thank you.
Greetings.
Hi, I wanted to add this information of the installed LTE module:
Quectel
EG18
Revision: Eg18eapar01a12m4g
How do I do to return to the original Zyxel version "Eg18eapar01a08m4g? Thanks.
Greetings.
was V1.00(ACBQ.0)b6 your fw version?
Hi, I don't remember what the previous version was, I'll recover the data and let you know.
Greetings.
I found the version, the one I had previously was "V1.00(ACBQ.0)b6".I continue to have problems with the "VOLTE" I did a factory reset and it started working again but after a long period of the device being unused,
I turned the router back on and the VOLTE no longer works.Strange thing. I don't know if there is any update available.
- 244 Nebula Ideas
- 6.9K Security
- 803 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
