USG Flex 200H - Impossible to send config via email
Hello everyone,
I upgraded to 1.21 firmware and as you can see it's impossible to send a backup config via email:
While the connection test is passed:
Is there a place where to set an autosend config when something is changed like it happens with "old" USG Flex and ATPs?
Hi @GiuseppeR , @PeterUK ,
The issue as unable to send the backup configurations via email will be resolved in the next firmware version, scheduled for release in October 2024.
Please refer to the Firewall New & Release section for updates on fixes, new features, and enhancements.
Zyxel_Judy
Hi @GiuseppeR ,
To better assist you with the auto email sending issue, we kindly request remote access to your device via Web-GUI and SSH. This will allow our team to conduct a thorough investigation.
Please check the inbox and send us the related information. Thank you!
Zyxel_Judy
seeing the same problem here
Sure I get my Daily Report fine
Hi @GiuseppeR ,
We are pleased to inform you that this feature is currently in development and is scheduled for release in our next firmware update (Q4 2024).
Zyxel_Judy
Hello @Zyxel_Judy,
thanks for the update 😍
Zyxel_Judy
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
