how to fix smart mesh link to 2,4ghz
Gescad
Gescad Posts: 6  Freshman Member
i have 6 AP in MESH mode, many AP have uplink to 5ghz but signal is very low, in 2.4ghz signal is better… is possible to block mesh link to 2,4 ghz for a better signal? i can't find settings to do this, please help me
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @Gescad ,
    To configure a 2.4GHz mesh connection:
    • Navigate to Devices > Select Access Points
    • Choose the specific AP you want to configure
    • Click on Smart Mesh > In the Band section, select 2.4GHz
    This process allows you to set up your mesh network to operate on the 2.4GHz frequency band for the selected access point.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @Gescad ,
    You're right. The mesh band selection is not available in some access point models including NWA1123-AC PRO.
    In your case, just fine-tune the placement of your root and repeater access points. Ensure that APs are deployed within areas with sufficient signal coverage, ideally at –70 dBm or higher for 5GHz. You also can adjust your 2.4GHz radio power to 5dBm lower than your 5GHz radio to reduce the interference between APs in 2.4GHz.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @Gescad ,
    Zyxel_Judy
    Untitled Image
  • Gescad
    hi, band selection is an option not available, i have access point model
    NWA1123-AC PRO
  • Zyxel_Judy
    Hi @Gescad ,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
