USG Flex 200H - Impossible to send config via email
GiuseppeR
GiuseppeR Posts: 324  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited August 2024 in Security
Hello everyone,
I upgraded to 1.21 firmware and as you can see it's impossible to send a backup config via email:
While the connection test is passed:
Is there a place where to set an autosend config when something is changed like it happens with "old" USG Flex and ATPs?
  • Zyxel_Judy
    Zyxel_Judy Posts: 1,935  Zyxel Employee
    Hi @GiuseppeR , @PeterUK ,
    The issue as unable to send the backup configurations via email will be resolved in the next firmware version, scheduled for release in October 2024.
    Please refer to the Firewall New & Release section for updates on fixes, new features, and enhancements.
