Bug report: NWA130BE UI - stations info
CecilWard
CecilWard Posts: 11 image  Freshman Member
The stations info display uses fonts that are too large, so that info in columns is displayed truncated. For example IPv4 addresses don’t show the low byte and half of the MAC addresses isn’t visible. This on the larger iPad Pro, so the window is large, and it’s in landscape mode.
A second bug: if you change the font size it draws smaller text, but in a narrower table, with narrower column, not using the full size of the available screen width even in landscape mode. Clearly the window size / screen width should be used to calculate the table width and its column widths, not just the font size alone.
Because of these bugs, the layout is not usable.
Please report these bugs for me.
