USG Flex 700 5.39 (ABWD.0)
RemonB
RemonB Posts: 7 image  Freshman Member
Installed yesterday newest update 5.39 (ABWD.0) but SSL VPN connection does not work any more.
SecuExtender gives error Code 9: No answer from Gateway.
Someone else with same issue?
Thanks in advance
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @RemonB,
    Have you checked the event log SSL VPN category if the USG FLEX 700 receives the VPN connection?
    Zyxel Melen
  • RemonB
    We tried to downgrade the USG to 5.37 it came with an error and after the reboot. Device message: Boot Status: Previous firmware update failed! But 5.39 is active and it works now and all clients can login again… very strange
    USG received incoming VPN connection before firmware downgrade but came with error that user / password is incorrect
  • Zyxel_Melen
    edited September 2024
    Hi @RemonB,
    Thanks for the feedback. Could you provide remote access for us to check? I will DM you for the information.
    Update: Issue has been solved by reboot the device.
    Zyxel Melen
