USG Flex 700 5.39 (ABWD.0)
Hi @RemonB,
Have you checked the event log SSL VPN category if the USG FLEX 700 receives the VPN connection?
Zyxel Melen0 -
We tried to downgrade the USG to 5.37 it came with an error and after the reboot. Device message: Boot Status: Previous firmware update failed! But 5.39 is active and it works now and all clients can login again… very strange
USG received incoming VPN connection before firmware downgrade but came with error that user / password is incorrect
Hi @RemonB,
Thanks for the feedback. Could you provide remote access for us to check? I will DM you for the information.Update: Issue has been solved by reboot the device.
Zyxel Melen0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 307 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
