Accidentally Booted to Config 2...
I can no longer access switch through IP address. I assume that config 2 assigned it a DHCP address because it's still working on our network.
How can I force to to reboot to Config 1?
Hi @doug_stone
Could you please let us know which switch model you are using?
If the switch is set to obtain an IP address via DHCP and you cannot access it, here are two steps you can follow to resolve the issue:
- Connect the switch to a network with a DHCP server so it can obtain an IP address automatically. Once the IP is assigned, you should be able to access the switch.
- Use the ZON Utility to scan your network for the switch. This tool allows you to reconfigure the IP settings, including switching it back to a Static IP. For detailed instructions, you can refer to this post:
Once you've regained access to the switch, you can reboot it into your preferred configuration.
Kay
Hi @doug_stone
Kay
Thank you. I was able to connect to the DHCP IP address and boot back to Config#1.
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
