Bug report: NWA130BE UI - stations info
The stations info display uses fonts that are too large, so that info in columns is displayed truncated. For example IPv4 addresses don’t show the low byte and half of the MAC addresses isn’t visible. This on the larger iPad Pro, so the window is large, and it’s in landscape mode.
A second bug: if you change the font size it draws smaller text, but in a narrower table, with narrower column, not using the full size of the available screen width even in landscape mode. Clearly the window size / screen width should be used to calculate the table width and its column widths, not just the font size alone.
Because of these bugs, the layout is not usable.
Please report these bugs for me.
Hi @CecilWard ,
Thanks for pointing out this issue. The spec of access point's Web GUI did not support iOS, that's why you were not able to see the full content when using iOS device. I have helped to create an idea post and we will monitor its comments and votes to evaluate this idea.
For the IPv6 part, our spec for the station information only displays IPv4 information. I have also helped create an idea post for this requirement.Zyxel Melen0
Hi @CecilWard,
Could you take some screenshots and share them with us? This can help us to clarify this issue better. Thanks.
Zyxel Melen0 -
Another thought: Where is IPv6? In the table only IPv4 addresses are listed. What about stations that only have IPv6? What about stations that don’t use IP at all, but use other L3 protocols or solely L2 protocols on the WLAN? Unlikely, I know, but far from impossible.
This is possibly a design bug based on a spurious assumption. My router shows all hosts in its ARP/ND table, with all associated IPv6 and IPv4 addresses.
Hi @CecilWard ,
- 435 Beta Program
- 183 Nebula Ideas
- 120 Nebula Status and Incidents
- 6.2K Security
- 439 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 433 News and Release
- 91 Security Highlight
