Flex 200H - Dual partitions for upgrade
Hello everyone,
I needed to upgrade this firewall remotely:
And everything was OK:
But I see only one partition available for firmware test.
Wouldn't it be better to always have the double partition available?
An easy way to have also the "Standby" one instead of only "Running" one like I have on all other Flex/ATP series?
Thanks a lot
Best Answers
It does have dual partitions you just don't see it the upgrade will always be to standby.
To see both run SSH
edit running
gui system standby-firmware-display true
commit
copy running startup0 -
Hi @GiuseppeR
As @PeterUK mentioned, the USG FLEX 200H does have dual partitions, even though only the "Running" partition is shown in the web GUI. The new firmware is uploaded to the "Standby" partition, and the device boots from there. This design simplifies the process and prevents confusion for some users.
If you prefer to display the "Standby" partition in the web GUI, you can do so with a CLI command. Please refer to this FAQ article.
Kay
To see both run SSH
edit running
commit
Hi @GiuseppeR
Kay
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
