XMG1915-10EP Certificate display bug
Fields are offset. 'Issuer' column displays expiration date, 'Valid From' and 'Valid To' are empty.
Note: This is a wildcard certificate that displays correct data in other Zyxel devices like GS series switches and 200H firewall, so there's nothing wrong with certificate.
Hi @bbp
In light of the issue you raised, we recently reviewed all of our switch models regarding certificate display. We noticed that for switches with firmware V4.80 or above, there is a display bug. However, for switches with firmware V4.70 or below, the certificate display in the web GUI is correct. Therefore, we would like to reconfirm the model and firmware version of your GS series switch.
Thank you for providing this information. We are currently reporting the issue to the relevant team for further enhancement. We will keep you updated on any progress.
Kay
Why is that relevant? The only reason I mentioned it is to assure that certificate is OK, and that they correctly display from/to dates, not only on other Zyxel devices (GS1900-16, GS1900-24E, both on firmware 2.80, 200H, on 1.21 and VPN100 on 5.37) but also other brands. The only device that I have and it doesn't display correctly is XMG1915-10EP.
Certificate is fine, display in Web GUI isn't. Just a minor bug that I was reporting. Nothing critical.
Hi @bbp
Kay
Thank you for the help, Kay.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
