Lack of details: Organization-wide manage > Change log
Hello everyone,
I was looking into Change log to search if there was a trace about a pair of manual updates that I clicked to force 5.39 firmware upgrade on a Flex100 that is not responding as I expect.
Those two upgrade attemps happened this morning, so I asked Nebula to show me last month of logs but no details inside it:
As you can see there are no used keywords so everything should be visible and the range was from 10th August up to the moment when I saved the screenshot.
Is there another place where to search logs?
Hi @GiuseppeR
You can currently check the firmware upgrade log under Site-wide > Monitor > Firewall > Event log.
At the moment, changes related to firmware management are not included in the Change Log. We recognize that these should also be considered configuration changes and displayed accordingly. We're planning to enhance the Nebula Control Center interface to include this feature, targeting the end of October for this improvement.
Thank you for bringing this to our attention.
Regarding the issues with your firmware upgrade, we will keep you updated on the other forum thread:
Kay
Hi @GiuseppeR
Kay
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
