NWA510 & NWA710
john32
john32 Posts: 7  Freshman Member
Is there a recommended Nebula configuration when using a NWA510 with a NWA710 on the LAN2/WAN Port?
When we have a project with a poor network signal we are planning to install a NWA710 externally and then connect it to the WAN port of the NWA510.
e.g. Can the NWA510 be demoted to a security gateway?
John
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,430  Zyxel Employee
    Hi @john32,
    Do you mean FWA510 & FWA710? It is rare to see a place that has outdoor and indoor mobile routers. Normally, FWA710 will connect to a firewall's wan port, like the USG FLEX H series/USG FLEX series/ATP series. Although FWA510 provides simple firewall service, if you need more security services, like content filter or application patrol, you still need a real firewall for these functions. Could you share the reason you want to use two mobile routers in this project? Is there any possible to have a physical ISP link?
    Zyxel Melen
  • john32
    Thanks for getting back to me.
    We will look at sourcing an alternative firewall/AP.
    Currently we setup sites with a FWA510 and try to resolve mobile network coverage/performance with placement and alternative networks, At the point we cannot achieve acceptable performance we would look to move the mobile device externally hence adding a FWA710.
    We do not have the option of fixed line communication in this environment due to the short nature of our contract/works.
    John
Nebula Tips & Tricks
