Can I connect two Zyxel XMG1915 switches to get more ports?
Hi all,
from my requirements, XMG1915-18EP would be my perfect switch to buy. However, the fan is quite a problem, as I will have the switch near my desk and I am sensitive to that fan noise. I have read posts that the fan can get noisy.
Thus, I thought that I will get XMG1915-10EP and the XMG1915-10E which are both fanless. and give me the same ports.
My question is: can I use the uplink port to daisy-chain those switches using, for instance, the DAC10G-1M-ZZ0103F 1m sfp+ cable? I have searched the documentation but the closest thing I found was stacking (failover setup), but that's a different story and stacking is not available in those models?
Will it be possible to have a logical large switch, e.g. to have ports from two switches in the same subnet?
Thanks!
Best Answers
Of course, you can use the DAC cable to link those switches with a daisy chain and get more ports. And these switches will also be in the same subnet/LAN. But the switch settings are independent. So, you need to set two switches separately.
Zyxel Melen0 -
You may take a look at the product photos first; the link is below:
There are no screw holes on the side of XMG1915-10E/EP for screwing the rack mount.
Zyxel Melen0
Zyxel Melen0 -
Thanks for your reply. That's good news. Some more questions:
- 1 DAC cable is enough or should I use 2 for link aggregation?
- What is the official name for that feature? I have searched the documentation and daisy-chain was not mentioned at all.
- Is there any rack mount kit compatible for 10 inch for those switches? Something like that, but the xmg1915 series is not listed: https://letmerepair-direct.co.uk/products/zyxel-original-rack-mount-kit-4-4sc-with-8x-screws-black
Thanks again!
This depends on your usage. However, you need to evaluate what port you will connect the XMG1915 to your uplink device.
Connecting two switches is a normal topology/connection. This is not a feature or function.
Let me check for this and update you later.
Zyxel Melen0 -
The XMG1915-10E/EP is a desktop model, which doesn't support the rack mount kit. Or are you going to purchase XMG1915-18EP?
Zyxel Melen0 -
The XMG1915-10E and XMG1915-10EP are 250mm so even if you get a 10 inch rack shelf it will not fit
What about 19 inch rack? I have both 10" and 19" wall racks available. I could put it on a floor plate instead but I was looking for a more stable setup. I don't want to get the XMG1915-18EP because it would be placed very near to my desktop and several reviews have shown that the fan is not silent but noisy. I do not want to switch the fan with a Noctua to avoid warranty loss at all. Though, I do really like the XMG1915-18EP.
Sure two 19 inch rack shelfs would work
Because of the fan I want to stick to the desktop models. I have seen 19" inch rack kits as well:
I will keep it on a floor.
as said you can't get rack kits for them models so rack shelfs is the only option
Zyxel Melen0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
