VPN don't work
Hi, we have a VPN configured, using L2TP.
It's not frequently used, but the last time it was working, 1 month ago, maybe…
But now it's showing a error message when trying to connect using windows VPN.
Error message: "Unable to connect to Palhoça Headquarters. L2TP connection attempt failed because the security layer encountered a processing error during initial negotiations with the remote computer."
I have tried to connect using three different connections but same error ocurred.
Someone can help?
Best Answers
Hi @Integrasul,
Thanks for the privilege. I found some failed logs which are related to the phase 1.
And I can use my laptop to connect the VPN to your firewall. Therefore, I think this issue is more likely related to the client side.
Could you help to check these things?
- The PC have updated to the latest Windows update? This is to avoid old Windows update cause L2TP connection issue.
- Could you help to check the Windows registry "AssumeUDPEncapsulationContextOnSendRule" has been changed to Value "2"? The path is "HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Services > PolicyAgent"
- Could you help to delete the VPN connection profile and add it again?
Zyxel Melen0 -
Hi @Integrasul,
I understand that you have changed the PC to crosscheck. However, these PCs might tested in the same network. Please help to create "AssumeUDPEncapsulationContextOnSendRule" if you don't have one. And step 3 I mentioned is to use the Windows built-in VPN creator to add the VPN profile.
Zyxel Melen0
Hi @Integrasul,
Could you enable Zyxel support access for checking?
[Nebula] How to turn on Zyxel Support Access? — Zyxel Community
Zyxel Melen0 -
Ok, I have enabled now.
Hi @Integrasul,
Zyxel Melen0 -
Hi, I didn't find this registry entry
Also, we tried in three different PCs here, that used to work in the past
Hi @Integrasul,
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
