VPN SSL
Institut_FIMAC
Have you planned to add VPN SSL fonctionnality ?
It's currently not in our roadmap, have you consider the L2TP over IPSec, the data also encrypted and it's supported on every PC or mobile device, the user don't need to install the third party application.
/ChrisChris
Hi,The client and router configuration is more simple and your licence rule don't need to buy licence for SSL.+1 for add SSL in your roadmap.Thanks.1
I also would like SSL VPN to be enabled in Nebula, especially for the new USGFlex firewall. There are a lot of businesses that require SSL-encryption because of safety and other compatibility issues.1
I made this wish last year, but still would like this option, some customers have issues with using L2TP over IPsec, due to ISP setup.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
