WiFi Extender
dgrooman
dgrooman Posts: 4 image  Freshman Member
We have a medium business with several WAX630S Zyxel APs in our building but we have some dead spots. Are there recommendations for extending our current signal? Would the NWA50AX be a solution? Thanks, Dave
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,584 image  Zyxel Employee
    Hi @dgrooman,
    NWA50AX might not be a solution for you since some of the supported functions that WAX630S have, NWA50AX might not supported.
    I suggest checking the device function table in the Nebula Help Center to find the compare model.
    Zyxel Melen
  • Zyxel_Melen
    Hi @dgrooman,
    Zyxel Melen
Nebula Tips & Tricks
