Guest WiFi network on USG60
I am back for a new question : we had to reconfigure a whole customer network using its own USG60. We had to reconfigure everything because nobody had any password/credential to access all Zyxel equipments.
So we reste all equipments and started from fresh installation. The customer has an USG60 and 5 mangeables access points (which are managed by my USG60) :
(even if 3 are visible here, the 2 others are down)
I used the wireless wizard to create a private and a guest wifi networks :
But it seems that there is no isolation : when I am connected on my guest wifi (SSID : "PUBLIC") I can manage to access my local servers and shares (which shouldn"t be the case).
Can someone tell me where I should have a look in order to fix this issue ?
Another question, how many accesspoints can an USG60 manage ?
Regards
Regards
@NoCoZ
Regarding to this case,
if you create AP profile from easy mode, the device will manage the AP via Guest interface.
Go to zone> move Guest to member list and Create the security policy rule to isolate Guest interface communicate with with Lan server.
The managed AP Number of USG60 is 2/18(default/Maximum)
Charlie0 -
NoCoZFR, I would create a VLAN in firewall, apply to Switches, and Access Points guest profile. This will put it on a different network. IE default network 192.168.1.X and Vlan network 192.168.10.x use VLAN 10 naming.0
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
