My Zyxell GS1920 can be access through SSH but not by the web gui
G15onsultores
G15onsultores Posts: 1  Freshman Member
Fourth Anniversary
Hi I have a Zyxell GS1920 switch, if I login using putty it takes user and password but if I try to do it with the web browser it wont work it says that user or password are incorrect and keep asking for login
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,716  Zyxel Employee
    edited September 2024 Answer ✓
    Hi @G15onsultores,
    May I know the firmware version of your GS1920 first?
    In addition, please try these methods before accessing the switch:
    1. Clean the browser cache.
    2. Try another browser, like Edge, Firefox, or IE mode if your switch is using a firmware version older than V4.70.
    Zyxel Melen
  • Zyxel_Melen
    Hi @G15onsultores,
    Zyxel Melen
