Switch - GS1920-48HPv2 - PoE issue
vince_76600
vince_76600 Posts: 2 image  Freshman Member
Hello, I am trying to power a Wifi access point ( ubiquiti NanoBeam 5AC Gen2 ) via the GS1920-48HPv2 switch, without success.
The Wifi access point works correctly using the PoE adapter supplied by the manufacturer, along with the access point, using the same RJ45 cables.
But when I want to power directly via the GS1920-48HPv2 switch, the access point doesn't start.
I've tried changing the switch settings in “PoE Setup” ==> “802/3af” - Nothing.
I've tried changing the switch settings in “PoE Setup” ==> “802/3at” - Nothing.
The access point manufacturer assures that the access point is compatible with “802/3af” & “802/3at”.
I've just received the switch, and maybe I've missed something in the configuration.
if anyone has any ideas to help me out, I'd love to hear from you.
Vincent
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,624 image  Zyxel Employee
    Hi @vince_76600,
    I checked the spec of NanoBeam 5AC Gen2, it seems like the power method of this device is "Passive PoE 2-pair (4, 5+; 7, 8 return)", this means this device can only be powered up by the PoE adapter. Therefore, you cannot use a switch to power it up.
    Zyxel Melen
  • vince_76600
    OK. Thanks for your clarification.
    I'll have a look at Zyxel's Wifi PoE solutions.
    Have a nice day.
  • Zyxel_Melen
    Hi @vince_76600,
    Zyxel Melen
  • vince_76600
    Have a nice day.
