Switch - GS1920-48HPv2 - PoE issue
Hello, I am trying to power a Wifi access point ( ubiquiti NanoBeam 5AC Gen2 ) via the GS1920-48HPv2 switch, without success.
The Wifi access point works correctly using the PoE adapter supplied by the manufacturer, along with the access point, using the same RJ45 cables.
But when I want to power directly via the GS1920-48HPv2 switch, the access point doesn't start.
I've tried changing the switch settings in “PoE Setup” ==> “802/3af” - Nothing.
I've tried changing the switch settings in “PoE Setup” ==> “802/3at” - Nothing.
The access point manufacturer assures that the access point is compatible with “802/3af” & “802/3at”.
I've just received the switch, and maybe I've missed something in the configuration.
if anyone has any ideas to help me out, I'd love to hear from you.
Vincent
Best Answers
Hi @vince_76600,
I checked the spec of NanoBeam 5AC Gen2, it seems like the power method of this device is "Passive PoE 2-pair (4, 5+; 7, 8 return)", this means this device can only be powered up by the PoE adapter. Therefore, you cannot use a switch to power it up.
Zyxel Melen0 -
OK. Thanks for your clarification.
I'll have a look at Zyxel's Wifi PoE solutions.
Have a nice day.
Hi @vince_76600,
Zyxel Melen0 -
Have a nice day.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
