Real ATP 500 AV Throughput ?
Hi
A simple test with ATP500 Firewall.
I downloaded this file : http://test-debit.free.fr/1048576.rnd
With ATP 500 Anti-Malware DISABLED : 960 Mb/s (Fiber 1Gb/s seem to be full)
With ATP 500 Anti-Malware ENABLED : 130 Mb/s !!!
AV version : 2.0.2.20190215.0
ATP 500 : V4.32
Is it normal ?
Thanks,
Lieveaux Cyrille
Best Answers
@Cyrille
The throughput will be affect when you enable the Anti-Malware.
Since the anti-Malware need to decrypt and analyze each packet, therefore, it will consume numerous performance.
On our lab, we send 2G file with single session, when disable anti-malware, the throughput is 912Mbp/s. When enable Anti-malware, the throughput will be 181Mbp/s. However, the statistic of throughput may be different by test machine or test process.
Charlie5 -
Zyxel_Charlie said:When enable Anti-malware, the throughput will be 181Mbp/s.Ok Accepted answer, ATP500 real throughputis less than 200Mb/s with Anti-Malware.
I do not think this is quit slow.. You can find in the datasheet throughput stats with Anti-Malware active. (700 Mbps) I want to remind you that this is a lab test based on UDP packets.. As you know normal internet traffic is UDP and TCP traffic, this value is not actual what you will get on normal usage. Take 1/3 of this value and you will have an actual value to hold on to.. so 700/3= 233Mpbs..
If firewall is enabled, the throughput may be lower. That in my eyes is normal throughput for this device..
Following as I'm looking to deploy fiber for clients.0
Not satisfying at the moment.Zyxel French support says : "We haven't test ATP500 throughput at the moment, we don't know if it's normal"So I disable Anti-Malware to get a correct Web throughputFor the VPN it's complicated too. VPN Between ATP500 and VPN100 is only 150 Mbp/s. A test other encryption (AES 256, 3DES, etc...) but nothing change. Maybe another setting in router but forum support technicial don't answer.
@Cyrille
Charlie5 -
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
