ATP800 is using higher RAM, exceeding 90%, leading it to not being accessible sometimes
i am encountering another strange issue that i believe you have help with. I noticed that our ATP800 is using higher RAM, exceeding 90%, leading it to not being accessible sometimes, and can lead to traffic drops or being unresponsive. There is nothing strange we are doing on the gateway, and almost most of the services are not working. I have attached diaginfo.
I always thank you for support.
Eric.
Hi @emuda,
According to your update, this issue has been solved. I want to mentioned you that your firmware version is not the latest version. It is recommended upgrading to the latest firmware version, which fix many vulnerabilities.
Zywall USG FLEX Series & ATP Series - V5.39Patch 0 Firmware Release — Zyxel Community
In addition, please help to monitor if the RAM/memory usage gets high again. Once it happens, please feel free to contact us.
Zyxel Melen0 -
Hi @Zyxel_Melen,
The issue was resolved by rebooting the gateway. But since then, I've observed a gradual increase in memory usage, which has risen from approximately 18% to 37% in less than 3 weeks.
I will continue to monitor it throughout the week and provide updates if any significant changes in memory usage.Additionally, I've upgraded to the latest version as recommended, which we hope will address the underlying problems.
Thank you for your time and support; it's greatly appreciated.1 -
Hi @emuda,
Thanks for your update. Please feel free to reach us again if the issue happens again.
Zyxel Melen0 -
Hi @Zyxel_Melen,
On September 23rd, memory usage was at 37%. Now, three weeks later (Today), it has increased to 58%, indicating a 21% rise during this period. This suggests that something might be gradually filling the memory daily. Are there specific areas we should check, such as logs or other sources?
Eric
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
