Download library checksum
GiuseppeR
GiuseppeR Posts: 524 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
went online to download a firmware and I noticed that the declared SHA is incorrect:
As you can see there is SHA2 while it should be displayed SHA256
    PeterUK Posts: 4,162 image  Guru Member
    edited September 2024
    Not sure what the point of the checksum is for FLEX H as you can't download release firmware and only by FLEX H or testing firmware
    yes ATP you can download firmware for maybe SHA2 is just short for SHA256?
  • GiuseppeR
    This is not related to 200H, it is related to firmware general availability.
    I went on that webpage (download library), when downloading firmware for ATP800 I saw that you could verify the HASH. Very nice.
    Anyway it could be better to write SHA256 because SHA2 includes SHA-224, SHA-256, SHA-384 and SHA-512. Considering it a typo I suggested a very slight modification
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279 image  Guru Member
    Hi @GiuseppeR
    Thank you for bringing this issue to our attention.
    I agree that displaying the correct algorithm for the firmware checksum would be beneficial. I have forwarded your concern to the relevant team.
    They will address the issue of the firmware checksum display on our Download Library in a future update. I will keep you informed of any progress by posting updates in this thread.
    We appreciate your feedback as it helps us improve our services.
    Kay
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,013 image  Guru Member
    Update:
    We will change the checksum format from SHA2 to SHA2-256 in the future.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    thanks a lot for this feedback, your support is great as usual. See you soon.
