USG40 - Set up Port Forwarding
RBattaglia
RBattaglia Posts: 4 image  Freshman Member
edited April 2021 in Security
Hello All,
I am new to the Zywall universe so I have not set up any port forwarding before on one of their devices.  I need to open 1723 to our server for VPN access.  I know that the USG40 has its own VPN but I am going to be retiring this server and adding a new one in a week. I just found out that there is one person that needs to access the VPN the old way by porting into the server on 1723.
So how do it do this?  It seems very confusing since on an Ubiquiti I just added the port foward in the NAT/Firewall rules.  This seems like I need to add services and then use those services.  Any help or suggestions would be greatly appreciated,
Regards,
Rob
    PeterUK Posts: 4,413 image  Guru Member
    Go Network > NAT > add
    Virtual server
    Incoming Interface wan1
    External IP any or make address rule with Interface IP wan1
    Internal IP the VPN server IP
    port mapping type Service-Group
    External service VPN_PPTP
  • iSpeed
    iSpeed Posts: 110 image  Ally Member
    You can also switch to easy mode and use the wizard included.
  • RBattaglia
    All set.  Thanks for your hlep.
