NWA130BE - No SSID, AP LED flashing green
I guided trough the wizard several times, tried different passwords but there is no ssid visible. I rebootet the AP, tried a 2nd ssid profil with different security settings. Nothing.
I cant see any error or wrong setting. What im doing wrong, what could be the mistake?
Greetings
Best Answers
Hi @Peter5_,
Thanks for the files~
Both devices are because of the limited power. May I know how did you power up these APs? Please help to check if your PoE switch uses 802.3AT mode to power up your APs. Or you can use the power adaptor to power up your APs.
NWA130BE power informationRegarding your suggestion, I will check with our team if we can have this notification window.
Zyxel Melen0 -
Hi @Peter5_,
Based on your test result, this issue is more likely an IPO issue between your switch and NWA130BE.
You may:
- Enable the "Force Power mode" to fix this issue.
- Consider the XMG1915-10EP to ensure optimal performance and reliability.
Zyxel Melen0
Hi @Peter5_,
Could you help to collect the diagnostic info for me to check? Please reference this FAQ to collect.
Zyxel Melen0 -
Sure Melen. I upload it here in the forum? 2 APs are connected. But the same problem. I updated both to newest firmware, atm they have internet connection.
I CANT upload .tar or .tar.bz2 (you use bz2 for diagnose and cant upload it?)
Delete the link since the file has been downloaded.btw. it would be cool if there was a error log windows where i can see myself what error is happening and why no ssid is broadcastet.
Hi @Peter5_,
Zyxel Melen0 -
I use PoE+ Switch and these 2 APs are the only connected devices that draw power over PoE+.
When i switch to "Force Power mode" it works. Is there a switch to "from limited to power" ?
(i use new rj45 cable (6a)).
Any idea what this could cause ? i can set the power usage to "30 watt" static but still not working
Hi @Peter5_,
You may:
Zyxel Melen0
- 211 Nebula Ideas
- 543 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 465 News and Release
