[NEBULA] NSW100-10P not showing online on the Portal
Hi @Draegan ,
I will PM you later for the latest firmware and the upgrade steps.
Please check your Forum Inbox.
Thanks.
Jason5
Hi @Draegan ,
Thanks.
Jason5 -
I have the same problem!!System Name - NSW100Product Model - NSW100-10PZyNOS F/W Version - V1.00(ABGO.1) | 01/20/2017
Megatro said:I have the same problem!!System Name - NSW100Product Model - NSW100-10PZyNOS F/W Version - V1.00(ABGO.1) | 01/20/20171
Hi @Megatro,
I will also PM you later for the latest firmware and the upgrade steps.
Thanks.
Jason0 -
I also have the same problem. The switch shows off-line !!!0
Hi @Papa_DIOP
I will PM you for detail information later.
Please check your forum inbox.
PS. Since the MAC address and the S/N is the personal information, I will remove it from your post due to security concern.
Thanks.
Jason0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
