how to use two different providers
davide_mds
davide_mds Posts: 1 image  Freshman Member
I have an USGFLEX50 to which I would like connected two different internet providers: FASTWEB connected to the WAN port and VODAFONE connected to the WAN2 port.
I would like to create two internal networks with different address classes: LAN (192.168.0.0/24) and VLAN (192.168.10.0/24)
I would like LAN uses WAN (FASTWEB) and VLAN1 uses WAN2 (VODAFONE)
I created two wifi in the external controller that manages the wireless networks, wifi_office should connect to LAN and wifi_production should connect to VLAN.
Is it possible? How can I do it?
Thank you very much
Davide
    PeterUK Posts: 4,446 image  Guru Member
    edited September 2024
    The Flex50 only have one WAN port but you can make VLAN external off that port for another WAN you will need a VLAN switch to do this
    for the switch given that both WANs will likely be untag like so
    Port 3 to FLEX50 WAN
    VLAN1 Forbidden port 1,2 and 3
    VLAN101 FASTWEB 1 and 3 untag port 2 and other ports Forbidden
    VLAN102 VODAFONE 2 untag and 3 tag port 1 and other ports Forbidden
    ports 1 and 3 PVID 101
    port 2 PVID 102
    have a zone for wan2 for the external VLAN
    make routing rules
    incoming interface LAN1
    next hop WAN1
    incoming interface LAN2
    next hop VLAN WAN2
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Does not OPT port allow WAN configuration, like this?
    I don't think the FLEX50 has a OPT
  • mMontana
    I took the screenshot from a RJ45-only version of a USG-Flex 50.
    I the same there is in SFP+RJ45 version.
