how to use two different providers
I have an USGFLEX50 to which I would like connected two different internet providers: FASTWEB connected to the WAN port and VODAFONE connected to the WAN2 port.
I would like to create two internal networks with different address classes: LAN (192.168.0.0/24) and VLAN (192.168.10.0/24)
I would like LAN uses WAN (FASTWEB) and VLAN1 uses WAN2 (VODAFONE)
I created two wifi in the external controller that manages the wireless networks, wifi_office should connect to LAN and wifi_production should connect to VLAN.
Is it possible? How can I do it?
Thank you very much
Davide
The Flex50 only have one WAN port but you can make VLAN external off that port for another WAN you will need a VLAN switch to do this
for the switch given that both WANs will likely be untag like so
Port 3 to FLEX50 WAN
VLAN1 Forbidden port 1,2 and 3
VLAN101 FASTWEB 1 and 3 untag port 2 and other ports Forbidden
VLAN102 VODAFONE 2 untag and 3 tag port 1 and other ports Forbidden
ports 1 and 3 PVID 101
port 2 PVID 102have a zone for wan2 for the external VLAN
make routing rules
incoming interface LAN1
next hop WAN1incoming interface LAN2
next hop VLAN WAN20 -
Does not OPT port allow WAN configuration, like this?
I don't think the FLEX50 has a OPT
I took the screenshot from a RJ45-only version of a USG-Flex 50.
I the same there is in SFP+RJ45 version.
- 601 USG FLEX H Series
- 480 News and Release
