NWA50AX - some device no longer connect since the firmware update
Hello.
I am the original creator of this thread. Last Monday I had a micro power cut and since then the problem was back: 2.4Ghz wifi no longer worked despite Nebula Control Center saying otherwise.
After multiple reboot and wifi set up changes, it seems to be back to normal. Hopefully the patch will be released soon to avoid further inconvenience
You may want to check the announcement this morning:
[Hotfix] 2.4 GHz Radio not Functioning Issue on NWA50AX, NWA55AXE, NWA90AX — Zyxel Community
Looks like a special hotfix patch has been released.
5 -
Thanks for the heads up. I tried to follow the instructions but got stopped due to an "invalid administrator password".
I'll wait for the v7 patch 3 as it seems to work for the moment.
Hello @Rodukas
Regarding the password, please use the Nebula site password instead, as your APs are managed on Nebula.
Direction: Configure > Site-settings > Device configuration section
Nami
This is indeed the procedure I followed, but it did not work.
- 431 Beta Program
- 2.6K Nebula
- 166 Nebula Ideas
- 6K Security
- 366 USG FLEX H Series
- 293 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 264 Service & License
- 408 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
