Zyxel router from Altibox
Berg
I am trying to connect my Melissa Home Connect to my Router, but how do i check Captive portals andMAC address restrictions?
EX3300-T0
Hello @Berg
Welcome to the forum.
If you look under Downloads and resources at the following link then you should be able to find the user guide for your EX3300-T0 router.
In response to the things your Melissa needs:
- Yes EX3300-T0 works in 2.4 GHz band
- No it does not have a capture portal
- Yes it can have MAC address restrictions, which Zyxel call MAC Filter. You should look under the Security menu of your Zyxel device.
I hope that this is helpful.
Kind regards Tony
- 601 USG FLEX H Series
- 480 News and Release
