ZyMesh open network once Smart Mesh was enabled on 3 AP
Hey Zyxel community!
Just wanted to ask you about some odd thing I noticed while I was setting up SmartMesh (2x NWA50AX + NWA55AXE)
When finally got it working I scanned to see how DCS is working on 2.4GHz channels.
All Ap's are creating some weird HIDDEN networks which according to inSSIDer software are all unsecured/open
Did you notice the same? What is it? Why is it open?
Hi @Mar_Cin ,
Could you share which AP management mode are you using, Nebula cloud or Standalone mode?
- For APs using Smart Mesh on Nebula: The Mesh profile is generated automatically as shown
- For APs using WDS Mesh in Standalone mode: You can add Pre-Shared Key to the WDS SSID profile.
Don't miss this great chance to upgrade your Nebula org. for free!https://bit.ly/4g2pS9L
I'm currently on Nebula management system.
I installed inSSIDer on other PC machine and it shows the same…0 -
Well, I run 'show running-config' on all AP's and each one of them returned this:
So seems like everything is correct and maybe inSSIDer is not?
Alright…
So.. Windows also sees that network as open…
What to do with that..? I'm really concerned about network security now…
Please help.0
- 414 Beta Program
- 2.3K Nebula
- 132 Nebula Ideas
- 92 Nebula Status and Incidents
- 5.5K Security
- 187 USG FLEX H Series
- 261 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1K Wireless
- 39 Wireless Ideas
- 6.2K Consumer Product
- 237 Service & License
- 375 News and Release
- 80 Security Advisories
- 24 Education Center
- 3K FAQ
- 80 About Community
- 69 Security Highlight
