MLO on NWE130BE - Performance slow with Iphone 16 Pro
i use a NWE130BE - works very fine! Last firmware, linked with 2,5GGb to a 10Gb-Core-Switch and a 10Gb QNAP-NAS.
I set up a new SSID to test MLO a few days ago. My Win11-Laptop with Intel BE200 and 24H2 works fine with MLO. No issues, very stable. More than 4Gb/s with iperf3 against my Qnap.
Since yesterday i have a Iphone 16 Pro. Connected to MLO-SSID as well, Nebula shows "MLO-Connected" on all 3 bands. Everythings seems fine, but the connection is slow. Iperf3 only show 500kb/s (same settings as allways).
When i connect it to the "old" SSID (Wifi 7 without MLO), it shows 700k/s. Again slow, but better.
Any recommendations how to setup the connection or do better testing etc?
Regards
Christian
Hi @Chris888 ,
I appreciate your feedback.
FYI: Our internal testing showed no performance issues when connecting an iPhone 16 Pro to the NWA130BE's MLO SSID as well.Zyxel_Judy
Hi @Chris888 ,
We haven't received similar reports from other users. Furthermore, based on your description, the Windows 11 laptop works well with the NWA130BE MLO SSID, suggesting there's likely no issue with the AP itself.
We'll continue to monitor this situation. In the meantime, we recommend contacting Apple support to investigate potential issues with their wireless card.
Zyxel_Judy
okay, i opened a ticket at Apple, too.
Regards
Christian
Today i´ve done some testing.
What i found: When i setup the new SSID with MLO, i used all my APs. One of them (NWA55AXE) provide only Wifi6 and no MLO.
Now i changed the SSID to only the NWA130BE.
My Iphone now (It was allways connected to the Wifi7-AP!) provide 1,5GB/s within the same IPERF3-Test.
Strange. :-)
Regards
Christian
Hi @Chris888 ,
Hi Judy,
thanks. Only to be clear, 1,5Gb is not what i expected.
I think it should be more than 3Gb.
But internet is full of reports about "slow" WLAN with Iphone 16 and Wifi 7.
Apple will find a solution…at the end it is a luxury problem.
Regards
Christian
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
