Nebula DHCP Option : Value is incorrect format
I am unable to add a DHCP option on a USG FLEX 200 Firewall with Nebula CC.
I don't understand the error because this configuation is in place in other sites.
There were errors in inputting this configuration:
- Value is incorrect format.
Hi @sebala,
Could you share the option and the Value you want to configure with me? When the type is TEXT, the Value column only accepts numbers(Current behavior).
Zyxel Melen0 -
i am having the same issue as sebala on a usg flex 100 manged by Nebula. I am trying to setup option 66 to boot and configure IP Phones:
A help will be greatly appreciated
Best Regards
Hi @RonyZ,
Thanks for your feedback. We are checking on this issue and I will keep you posted.
Zyxel Melen1 -
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 491 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
