XMG1915-10EP - POE / PD is interrupted when booting
Hi, I have noticed, that switch when booting is performing 2 or 3 restarts of POE (power delivery is interrupted and resumed).
I would like to ask - is there any way to avoid such a situation? This is unfortunately causing that some of my SBCs etc. devices are powered up and forcibly powered off, then powered up, and again…
Of course this may lead to data loss etc. or some problem with hardware itself.
If currently it is not possible - then maybe some feature request - "delay power on after boot". I mean - option that POE is enabled only when switch is 100% booted-up.
Please consider and thank you.
regards,
Marcin
Best Answers
Hi @mparka,
We have found a solution for this issue, which will be fixed in the next firmware release. The ETA is the end of December.
Zyxel Melen0 -
Thank you very much.
Hi @mparka,
I understand your concern about the power interruptions during the XMG1915-10EP boot process. I'm checking with our team if there is a solution and I will keep you posted.
Zyxel Melen1 -
Thank you @Zyxel_Melen - I will wait for a solution/suggestion if any appears from Zyxel team.
Hi @mparka,
Zyxel Melen0 -
Is the "solution" out ? Since there's a new Nebula firmware (4.80(ACGP.3)C0 ) available for XMG1915 series switch and I didn't see any mentioned on release notes.
Hi @cafebug,
I just confirmed the new firmware 4.80(ACGP.3)C0 fixed this issue. The release note missed this item; we will update it in the release note.
Zyxel Melen1 -
I have upgraded firmware to 4.80(ACGP.3)C0. As for initial checking it seems that reported POE/PD issue has gone (it is fixed) - after powering the switch up - it is not interrupted when switch is booting. Thank you.
- 441 Beta Program
- 293 Service & License
