Nebula FWA710 carrier agregation capability
xavier_france
xavier_france Posts: 2 image  Freshman Member
edited October 2024 in Nebula
Regarding Nebula FWA710 :
On the spec sheet, i can see this routeur can do 2CC agregation on 5G bands, but what about 4G :
Q1 : How many 4G bands can be agregated? 2CC, 3CC, 4CC?
Q2 : can it agregate LTE800 band and LTE700 band? (3GPP band 20 + band 28)
Q3 : and finally it is noted that the routeur has a directional antenna. Is it better to point the router in the direction of the best signal?
Q4 : Is it possible to install an external antenna to enhance performances? (what port shall it be plugged to?)
Thanks !
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,318 image  Zyxel Employee
    Hi @xavier_france ,
    • 1. In addition to LTE single CA, 4G bands can be aggregated as LTE 2CA, LTE 3CA, LTE 4CA, and LTE 5CA.
    • 2. The LTE B20+B28 2CA aggregation combination is not supported on the FWA710.
    • 3. It is recommended to point the router in the direction of the strongest signal (towards the base station).
    • 4. The FWA710 doesn't support external antennas.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @xavier_france ,
    Zyxel_Judy
    Untitled Image
  • xavier_france
    Thanks Judy
Nebula Tips & Tricks
