IKEv2 android e ios
spatai
spatai Posts: 4 image  Freshman Member
Hi, I followed this guide step by step:  https://support.zyxel.eu/hc/it/articles/8805317185298-VPN-IKEv2-con-chiave-precondivisa-su-dispositivi-mobili-invece-di-L2TP#h_01HB6CZ4685VCSJ22W1NW2J98E
but I can't log in to VPN, when I try to connect for example from Android, I get a message saying "connection not secure" and then nothing happens, can you help me please? Thank you
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,447 image  Zyxel Employee
    edited October 2024 Answer ✓
    Hi @spatai,
    Thanks for the screenshot. I did a local test with my Android 14 smartphone. Following the link you mentioned did not have the "not secure" message. Please help to check if this VPN profile is an old profile that uses L2TP protocol, and try to create a new VPN profile with IKEv2/IPSec with PSK.
    Zyxel Melen
  • Zyxel_Melen
    Hi @spatai,
    I found the issue is due to the Android didn't support big capital in the pre-shared key column. I can reproduce this issue in my lab. I fix this issue if I change the pre-shared key to small capital for all letters.
    Please help to change the pre-shared key on your firewall > VPN gateway settings.
    Zyxel Melen
  • Zyxel_Melen
    Hi @spatai,
    I would like to clarify with you:
    1. What is your Android version?
    2. Could you share the screenshot of the error?
    Zyxel Melen
  • spatai
    Firewall: ATP 100
    Android: 14
  • Zyxel_Melen
    Hi @spatai,
    Zyxel Melen
  • spatai
    Thanks… I have already done several tests by recreating the new VPN connection, but I receive the same error, to make sure that I have configured everything correctly, IP or FQDN of the firewall's WAN interface, is public ip right?
  • Zyxel_Melen
    Hi @spatai,
    Public IP is correct.
    Zyxel Melen
  • spatai
    So I configured all correcty by guide, but I can't understand why it doesn't work, What other tests could I do or an alternative route? Thanks
  • Zyxel_Melen
    Hi @spatai,
    Please check your community message box. I have sent you a request for further checking.
    Zyxel Melen
  • Zyxel_Melen
    Hi @spatai,
    Zyxel Melen
