VPN Site to Site Mikrotik to Zyxel flex 700
duythượng
duythượng Posts: 7 image  Freshman Member
edited October 2024 in Nebula
I want to support the configuration of VPN site to site from mikrotik device to Zyxel usg flex 700 device
typology : VPN Sitie to Site Zyxel To Mikrotik
Symptoms : do not ping zyxel to Mikrotik
Request : suport fix the problem
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,726 image  Zyxel Employee
    Hi @duythượng,
    Mikrotik side doesn't send any traffic, have you checked the security policies that are allowed for the VPN?
    Zyxel Melen
  • Zyxel_Melen
    Update conclusion:
    The VPN configuration on USG FLEX or Mikrotik side are both correct. This issue is due to the special topology that has some policy route rule that cause the traffic cannot pass to the correct interface. Adjust the policy route rule fix the issue.
    Zyxel Melen
Nebula Tips & Tricks
