VMG devices bridge mode not accessible via it's management IP
The idea ist to create a second interface group in the zycel . Name it "Management" or so bind it to Lan4 and to WWan as pseudo interface . Then give a single free IP Adress of your Net without DHCP or so and connect with a second Ethernet cable to your Net . Then you can reach it as a normal device in your net . Thats all ….
"WWan as pseudo interface"?
Is this what you mean?
What do you mean by "Then give a single free IP Adress of your Net without DHCP or so and connect with a second Ethernet cable to your Net"
? Which Net?
I have the new Interface Group setup without DHCP like this:
So now I connected cable from that LAN4 port into my network switch. Then what do you mean by "give a single free IP Adress of your Net"?
So what happens if you put in 192.168.5.1 in your browser ? You should get the gui of the Zycel device …
The page doesn't load. Pinging 192.168.5.1 from the PC (192.168.1.4) produces "Request timed out".
If you are really interested in you can put a Laptop direct over Lan4 to the zycel to see if it is connecting … If this is ok try allow a Routing form your local net to the Zycel with the different IP x.x.5.x then x.x.1.x .
I have two Interface groups and two nets x.x.1.x and x.x.2.x with my Zycel Router and can reach them both .
My primary LAN is 192.168.1.x. The "default" interface group for the Zyxel is 192.168.11.253. The new "Management" interface group is 192.168.5.1. Plugging laptop directly into the Port 4 of the Zyxel I can reach the management gui on 192.168.11.253 or 192.168.5.1, but not from any PC on the main LAN 192.168.1.x.
I have a firewall rule in my main router for the primary lan set-up to explicitly allow traffic from the primary lan to reach 192.168.5.1, but it doesn't seem to make any difference
So its true , you can reach the web GUI of the Modem via Lan4 and 192.168.5.1 .
You can make it easier to access with a Laptop when you activate DHCP for your x.x.5.1 Network of the new Interface group you called "Management GUI" . You could add the wifi of the Zycel to this new interface too.
To reach it via Lan4 connected to your local Network via Ethernet cable is another Question .
I think if a bridge modem is working on his adress yours is 192.168.1.253 it is not possible to reach it in the same time via a Laptop connected to another Lan port of the device ?
But over WLan it is possible .
So now the bridge modem offers a new adress 192.168.5.1 to login to the Web GUI on Lan4 .
You have to configure your synology for this , then you can see the logs etc. from a Computer in your local Network .
"I think if a bridge modem is working on his adress yours is 192.168.1.253 it is not possible to reach it in the same time via a Laptop connected to another Lan port of the device ?"
I'm afraid I don't follow what you're saying here. As far as I understand it, it should be possible to reach Zyxel at 192.168.x.x from 192.168.1.x. even if the Zyxel is providing internet into the WAN port of 192.168.1.1, as long as the Zyxel doesn't also have IP in the 192.168.1.x subnet so 192.168.5.1 or 192.168.11.253 should both work. But for some reason it's not visible.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
