[NEBULA] reset local admin password
FrankIversen
Is it possible to reset the admin password used at the local web gui from NCC? I have managed to forgot which password I set locally..
And in a case where an ISP want us to change the wanip but before we manage to do so we have lost the connection; we ould need to login locally.. BUY; could we reset the firewall and would NCC then apply all the security/firewall settings from NCC when the device comes online or will the locally ruleset wipe out the NCC config?0
If you device is managed by NCC and online, you can change password in Local credentials part through Site Wide > Configure > General Setting on NCC, and then use new password to login.
thx!0
Hi FrankIversen
As @LOL mention, If your NSG is managed by NCC and online, NCC will overwrite the password to NSG. Besides, if your NSG is managed by NCC and online, and then you reset the device, all configurations will be pushed by NCC.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
