Access point + switch location: worldwide edition
GiuseppeR
GiuseppeR Posts: 565 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited October 2024 in Nebula
Hello everyone,
since a pair of days when I look into my dashboard on my Companies I have this widget showing me a beautiful world maps instead of a detailed one as usual:
The useful view was this:
or this:
So to have back this view I have to click on the home icon:
I have the same problem with maps included in switch details pages:
Is it possible to have back the "home view" as default?
Thanks a lot
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 401 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    edited October 2024 Answer ✓
    Dear @GiuseppeR,
    Good day.
    As you can see on NCC, we have fixed this issue.
    Thanks.
    Ivan
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @GiuseppeR ,
    We have successfully reproduced the issue at our site. We will investigate further and inform you of any updates.
    Zyxel_Judy
    Untitled Image
  • GiuseppeR
    Hello @Zyxel_Judy
    since this early morning widgets regarding GPS position came back working properly.
    Both for switches:
    and for APs:
    Thanks a lot 😎
  • Zyxel_Ivan
    Dear @GiuseppeR,
    Good day.
    Thanks.
    Ivan
Nebula Tips & Tricks
