Virtual ethernet interface
itariant
itariant Posts: 20  Freshman Member
First Comment Seventh Anniversary
edited April 2021 in Security
I created a virtual interface on Lan1 (lan1: 1) to manage some devices on the network. Now, this interface has priority over client web authentication, the firewall login page is shown on the ip of lan1: 1
I think it's a Metric problem but it's not possible to set up.
How can I set priority to lan1 in the presence of a virtual interface?
  • nnadmin
    nnadmin Posts: 9  Freshman Member
    First Comment Sixth Anniversary
    Virtual interfaces add extra addresses to the USG itself; if you are trying to send traffic to a device other than the USG, you may wish to setup a NAT virtual server instead.
  • itariant
    this happens: on lan1 I activated Web Authentication and I created a virtual interface with ip 10.10.0.0; Client from lan1 is now proposed to authenticate on the USG on ip 10.10.0.1
    How can I bring authentication to 192.168.1.1?
    I thought it's a metric priority ..
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
    @A_Arienzo
    You need to create the subnet address test(10.10.0.0, 255.255.255.0), and Go to web authentication> Create the rule Source:test, Destination: any, Authentication: unnecessary. This rule need to be first priority.
    Charlie
