Nebula DHCP Option : Value is incorrect format
sebala
sebala Posts: 18 image  Freshman Member
First Comment Seventh Anniversary Nebula Gratitude
edited September 2024 in Nebula
I am unable to add a DHCP option on a USG FLEX 200 Firewall with Nebula CC.
I don't understand the error because this configuation is in place in other sites.
There were errors in inputting this configuration:
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,990 image  Guru Member
    Hi @sebala,
    Could you share the option and the Value you want to configure with me? When the type is TEXT, the Value column only accepts numbers(Current behavior).
    Zyxel Melen
  • RonyZ
    RonyZ Posts: 2 image  Freshman Member
    i am having the same issue as sebala on a usg flex 100 manged by Nebula. I am trying to setup option 66 to boot and configure IP Phones:
    A help will be greatly appreciated
    Best Regards
  • RonyZ
    i am facing the same issue as @sebala
    I am trying to configure Option 66 with a https url as a value for our ipphones provisionning.
    Any help would be greatly appreciated.
    Regards
    Rony
  • Zyxel_Melen
    Hi @RonyZ,
    Thanks for your feedback. We are checking on this issue and I will keep you posted.
    Zyxel Melen
  • Zyxel_Melen
    Hi @sebala & @RonyZ,
    This issue has been fixed. You may configure your preferred content now.
    Zyxel Melen
Nebula Tips & Tricks
