IPSec and 2FA do not work on FLEX 200 using Nebula setup
I have set up IPSec VPN server and L2TP VPN server up in my Flex 200, and downloaded windows script for VPN access
When i connect from Windows using L2TP it connect to the router and i have access to my LANs, but 2FA is not possible like my USG60.
When i connect from Windows using IPSEC it connect to the router but I have NO access to my LANs, When I enable 2FA in the IPSec config, nothing change in the connections process , it just connect and this is this , No portal appear.
Hi @Soeren_Hvid_DK,
This is because the Windows native VPN won't automatically pop up the 2FA verify portal.
Please reference this FAQ for more information:
Zyxel Melen0
Hi @Soeren_Hvid_DK,
Zyxel Melen0 -
I will test it as soon i get my IPSec remote VPN to work without 2FA
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
