TFTP setup for netboot.xyz
This week I changed isp and was given an EX3301-T0 which I see can assign a TFTP server.
I've built a docker container for netboot but the documentation points to needing to tell the DHCP server which files to use and where to go. How do I configure this on the router?
The only option in the gui for the router is to assign a hostname/ip for the TFTP server which I have done. ssh on the router shows a prompt of 'ZySH>' but I'm yet to find a command which will work.
Any help would be really appreciated as I'd love to get this working
You want to login to the UI for firmware upgrade via internal ftp of the device ?
No. I want to be able to configure the routers dhcp to point to another server and use that for pre booting.
I think I need to be able to configure the boot files but don’t see an option.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
